420 Steering
I took delivery of a new (2001) 420 in March, w/ factory installed Autohelm 7000. Overall the boat is GREAT. The Autohelm 7000 has been wonderful (example: holding the boat perfectly, running downwind with asymetrical spin. in 20-25 kts of winds on the Ches. Bay). Steering IS stiff, but not to the extent of the problem that you are experiencing. Did have one VERY SIGNIFICENT problem.... cable separated at quadrant eye-bolt last weekend of June as I was bringing boat into slip in difficult conditions and steering hard back and forth trying to keep boat's bow from being blown off. Total loss of steering ! ! ! Managed to get boat into slip with help of others in marina via quick use of lines to other boats, and a friends dingy used as a tug. The next day, used emergency tiller (you better check yours, it won't work as delivered) to take boat back to dealer. Norton's made repairs and have had no problem since. Probable cause: cable clamps that hold ends of steeering cable together (at eye-bolt on either side of quadrant) were never properly tightened or worked loose anyway. They are now secured w/ "loctight". Norton and Hunter admit that design is flawed, and (I understand) have changed steering design on newer boats. I would strongly recommend that all 420 (
