Jerry Raznov
I took delivery of my new 410 Aug 1999. For 12 months I worked with my dealer and Hunter to resolve several lingering concerns most of which are now resolved. Following are some items that no one seems to have an answer to:1) Grunert requires that the sea water cooling lines of the refrigerator compressor and 2 ea. AC compressors must be purged via a closed loop flow of 5% Muriatic acid solution for 30 min. every 6 months. I successfully completed this on the Refrigerator and Salon AC. How can the sea water input and output lines of the aft cabin AC be accessed? This raises a second concern how can the aft cabin AC compressor be removed if it requires service? It is sealed in a NO ACCESS compartment!2) Page 57D of the Hunter Owners manual states that the T's connecting the aft head shower to the aft head sink can be accessed through the Bilge Board outside the head. This is not the case. I believe these T's are located below the after cabin port seat. There is no way to get access since this seat does NOT come apart. Any suggestions?3) Over the past 12 months the aft fresh water tank sensor failed, the forward holding tank sensor failed, the aft holding tank sensor failed. Are other 410 owners having the same problems? What is the cause? What is the solution?4) Both House batteries, supplied by dealer are Interstate 4DXHD. Interstate and Heart Inverter state that deep cycle SRM4D batteries must be used. No resolution. How are your 410’s configured?
