Battery
Ed, I believe the reason for 2 batteries is so you can use one (HOUSE) and still have another fresh battery to start your engine. You'll probably have to figure the rest on your own, because noone else knows exactly what you're doing while on your boat. For example, let's say you have a 200 amp-hr battery: Typically, you can use roughly half of that, or 100 amp-hrs before it is considered to be 'dead'. BASICALLY what that means is that you can use 10 amps for 10 hours (10 x 10=100), 1 amp for 100 hrs, etc. If you don't care to do all that figuring, you can get gauges that monitor the "state-of-charge" of 1, 2, or more batteries. Boater's World offers the Goldeneye monitor, Sailnet has the Heart Link 10 and Link 20 models. I'm sure there are others. I have no experience with these devices, so I cannot fairly recommend any one over another.Anyway, the point here is that you'll have to determine by your own experience what you need for what you want to do. Just don't cheat & use the "START" battery if the house battery gives out in the middle of the party!I hope this gives you some useful info. Happy Sailing!Jim Maroldos/v: Lil' Wass Ett
