So... yet another of my triumphs er.. failings.
I installed a 12V cigarette-lighter-style outlet to allow easy charging of cell phones and other goodies on my H22 (and the operation of a spot light while under power at night till I get my running lights in order...).
From my experience with car stereos etc I really should have known better than to make this mistake, but after I drilled the hole for the outlet through the side of the dry sink and the shelving wall for the alcohol stove using my 1" hole saw, I still had to cram it in there pretty good to mount it flush. There may have been a hammer covered with a towel involved. I wired it up to the battery immediatly below my installation and zip tied the slack out of my wires. Clean install and looks good. Until -
During my previous adventure (see post "Stuck!") my buddy who was on the boat while I was in the water had trouble starting the motor using the power starter (Honda BF9.9 no remote). He had to use the pull cord. I assumed that was operator error like much else during that episode, until a week later when I came back in and prepared to re-start the motor to run the carb dry. Nothing. I verified the battery was in fact dead by starting with the pull cord, just as my buddy had done a week earlier.
Well you all already know the punch line. The 12V power receptacle has exposed leads at the back, which due to my cramming it in there are undoubtedly connected now causing a short and draining my battery. I'll be removing the thing this weekend and wrapping those leads in copious amounts of electrical tape, then cold-starting the motor using the pull cord (should only take 20 minutes of pulling...) before letting it run a bit to re-charge my dead battery.
Fairly warned be thee says I! As usual I'm just compentent enough to get myself into trouble. But, forgiving boat, small lake, lots of contingencies, all advisable safety equipment on board, and everything turns out ok.
