never turn battery selector switch to OFF while engine is running
272
Hunter 36 Forked River, NJ
I know that warning is scribed in bold letters beneath the battery selector switch, and I've read about the atrocities that could happen if someone disobeys. Let's just say a very intelligent and literate passenger was trying to be too helpful and turned this switch to off while my engine was running for a minute before I realized and corrected it. I have run DC accessories for awhile and been able to restart the engine, so feel slightly confident that the alternator wasn't damaged. Should I expect that turning the battery selector switch to off for even a second while running the engine will fry the alternator? If the batteries seem to be adequately charging by the alternator, should I feel confident? How can I be sure? Finally, how should that passenger be punished?
Dec 3, 2003
2,101
Your Voltage Regulator...
...should take care of any "overcharging" to the batteries if that problem should present itself. I don't know what will happen if the switch is turned "off".
Jim
May 21, 2007
775
Catalina 36 MK II NJ
I have done it and didn't
fry the alternator but only for a minute? I would think the longer it is on the more heat, the better chance you'll fry the alternator.
7,336
Alden 50 Sarasota, Florida
you should be fine
Although it is possible to blow the diodes in the alternator if the load is removed, it is unlikely and it would be obvious to you if it did occur. Most boats today are wired such that the alternator energized wire is direct connected so it depends on what type/how old your boat is and how it was wired. Regardless, it's easy to identify if the diodes were damaged - if the alternator is charging the batteries, you're fine. Recognize the alt will not show any significant charge rate on batteries already at full charge so don't be misled by the charge state.
Feb 6, 1998
11,701
A lot..
A lot depends on your state of charge when the switch was moved to the off position. If the batteries were at or near 100% the alt was barely working and switching it off may not have fried the diodes. If your bank was at 30% of capacity and your alt was cranking out 50-60 amps and the switch went to off you'd almost certainly fry the diodes.. Why did the guest switch it off to begin with?? Was there a need to do this?? P.S. The alt on some boats is wired directly to the house bank so that even if you switch the battery selector to "off" the load is still connected.
Nov 30, 2007
272
OFF
Thanks for your responses. I think I'll sleep better tonight. My passenger was asked to shut off the shore power switch because we were preparing to leave dock, and turned the battery selector switch to OFF instead. On my C28, the board is specifically labeled, and the manual explains that it's not designed to accomodate this action.
Phil
Bat guage
Does your boat have a battery meter? If the alt is still working your battery meter will show them in a charging state while the engine is running, ie 14 volts +/-. If the meter is showing 12.6 with the engine running I would say the alt got toasted. If your boat doesn't you could borrow a meter and check the voltage at the battery with the engine running.
From an earlier post about this subject
which comes up all the time on a regular basis; it discusses some other things, but much of it is useful, too, so if you want just home in on the alternator wiring part of the discussion: Separate ground from new alternator and use of the 1-2-B switch. Frank, this text belwo the ***s is from a recent post where someone was asking about a combiner. But if you get through that part, read about the basic intent of what I wrote. Only YOU know how your boat is wired and where the alternator output now goes. You also have to determine how you want to wire your new alternator, but Maine Sail's right that a 100 A alternator will most likely only put out 50 A on a deeply discharged large (400+ ah) house bank because of battery acceptance. In most cases #2 wire is actually overkill. Many new alternator manufacturers suggest using separate grounds from their ground posts, back to your NDP, which eventually ends up at the engine anyway. You could use the grounded case or a separate wire, but if the aletrnator is not a grounded case you NEED to use a ground wire. We have a 100A on our M25 with a single 3/8" belt. The link is to the whole older thread. *********************** *********************** It all depends on how it's wired U wrote: "Even with the old fashioned way, if you change the switch to both after the engine is started, won't the charging source voltage overcome the flow of volts from the strong battery to the depleted battery? Also for you electrical experts, do I have the correct understanding of how a combiner works?" The old fashioned way? That's generally where the factory wired it this way: ONE measly wire from the alternator output to the C post (BOTH setting) on the 1-2-B switch, with a small wire between the alternator output and the starter. Why? Because it was the cheapest way to do it. One wire that served two purposes: to start it took the current through the wire FROM the batteries to the switch to the alternator through the small wire to the starter and then engine started. Once started, the flow of current reversed in the wire and went from the alternator output to the switch C post to the batteries, depending on which position the switch was in. [Some builders used two wires, one to the starter and one from the alternator, without the small wire between the alternator and starter. The downside was that these two wires still went to the C post, when the alternator output should have gone to the house bank, and the starter wires is really the only thing that needed to be on the C post. See more below.] That's why people had (HAD) to start their engines on BOTH, or risked shorting out their alternators if they started on the start bank and then switched the switch - if it's contacts were bad, the alternator output stopped and fried the diodes. Some folks started on their start bank, then only switch to their house banks when the engine was turned off. The downside here was that the house bank didn't get charged when the engine was running. OK if you've been plugged in all week, not so good if you've been on the hook and wanted to go to another anchorage. The 1-2-B switch served two purposes: it was the gatekeeper for where the alternator output went: 1, 2 or BOTH batteries; AND once the engine was off, it decided which battery bank was the source of power. Actually, when the engine was running it was doing both functions! A combiner works this way: it's a simple relay, whenever it sees a voltage higher than its set point, it closes allowing current to flow. It has nothing to do with the "resting voltage" of anything. It's on or off, closed or open, simply based on a setting. The easy way to think about it is, if there is a charge source available, that charge source is always higher than the even-full battery voltage of 12.8 V, so most combiners are set around 13.0 V or so. You plug your shorepower charger on, or run your engine and alternator and 14.2 V or 13.8 V or somewhere in between, shows up and the combiner closes, allowing juice to flow to the second bank. The reason smart electricians now suggest wiring ALL of your charging sources to the house bank is because that's where the input is required, because most of the time start banks (or emergency banks as discussed in another recent thread) are full anyway. Think about it: a 60 AH start bank, 30 AH usable -- the starting takes about 2 to 5 AH out of the start bank -- that's all -- glow plugs (for some) and start, is high amperage for an extremely short period of time. So, with all of the charging outputs going to the house bank, the combiner will send some juice to the start bank. One of the keys to understanding this is that it is much better to avoid the danged 1-2-B switch with charging sources COMPLETELY, and only use the C post of the 1-2-B switch for output from the batteries: i.e., power to the starter and power to the distribution panel FROM the batteries. Avoiding anything on the 1-2-B switch for wiring TO the batteries simplifies matters greatly and also avoids any problems with the switch messing up the alternator - you can move the switch all you want, even turn it off with the alternator running (!) because its output is going directly to the house bank. What a concept! The "charging source voltage" will overcome the drain of one battery to the other. However, there are two different scenarios here which most people tend to completely ignore or misunderstand. One scenario is this: been away from the boat all week, boat's been plugged in charging both banks. So, going to BOTH will have NO consequences. NONE. The batteries are charged, they're both just fine. Second scenario: been on the hook, start bank is almost fully charged, house bank isn't. Going to both will potentially drain the start into the house with dire consequences if left in BOTH too long without starting the engine right away. As I mentioned in another recent thread, you have to think about it based on the condition of the batteries as well as how you have the boat wired. A combiner is good for two equal sized house banks where they are switched daily (again when cruising, NOT when plugged in), or when one is retained for starting (a useless and wasteful approach in my mind - why have all those batteries sitting around doing nothing, besides, it reduces the life of the batteries). An echo charger is superior to a combiner when you have a larger house bank and a small start bank because the echo charger limits the amperage flow and avoids overcharging the start bank if you motor a lot. Alternatively, you could use a combiner and put a switch in the ground wire to the start bank and shut it off when motoring for long periods. The ACR is a combiner with improved technology to avoid spikes when the house bank is fully depleted. Pretty much the same thing, same purpose for all three. Theoretically, putting the switch on BOTH will do the same thing as a combiner to parallel the two banks if you have the alternator output wired to the house bank. BUT, and this is a BIG, HUGE "but", you again have to think about the WIRING. Most boat builders run #4 wires FROM batteries TO the 1-2-B switch. This is fine sizing for a meager OEM 55 amp alternator output which rarely gets anywhere near 20 amp output, and the total battery output rarely gets near that (when was the last time you ever had EVERY SINGLE ONE of your DC loads ON -- lights, fridge, electronics, stereo) add the DC loads all up they just don't get that high. So, with the alternator output gong to the C post, the #4 wires were being used for two purposes, in two different directions: alternator output to C post to batteries, and battery output to the switch and the DC panel for loads. Now, when a bigger alternator with external or internal regulation is installed, the alternator output gets tripled to 60 amps and the #4 wires are WOEFUL INADEQUATE (if the alternator output remains tied to the C post of the switch - you're just asking for trouble or undercharged batteries). That's yet another reason to rewire your alternator output to the house bank directly, and use either a combiner, echo charger, duo charge, ACR or a simple manual switch, to send power to recharge your start (or second) bank. The use of B on the 1-2-B switch, if the wiring and components are designed and installed correctly, should be a thing of the past, regardless of what kind of switches you have installed. We've redesigned our system, but did it retaining the 1-2-B switch very deliberately in lieu of buying new switches of any sort. The alternator output goes directly to the house bank, we use a combiner to the start bank with a switch in the ground leg to turn it off if we motor a lot, and the OEM #4 wires FROM the batteries TO the switch are just fine because they are ONLY used for battery OUTPUT to the C post: i.e., the DC panel and the starter wire to the starter. We never use the B switch position, can start the engine on the start bank position OR the house bank position, and can switch the switch when the engine is running with no fear of damaging anything. PS Ed, I also recommend changing your alternator output FROM the start bank through the ACR to from the alternator TO the house bank through the ACR to the start bank. Reason is described above, the start bank is almost always full, so why run that current through the ACR all the time? Same instructions came with the combiners (and Pathfinders) -- ALWAYS run the alternator output to the house bank.
In addition to the wiring, here's another
discussion about turning the 1-2-B switch off when wired to the alternator output: OUTPUT Question Redux I asked Jim Moe, a C34 owner and a professional electrical expert, the following question, with his reply: Jim Re alternators and regulators. I've always been under the impression that if the 1-2-B switch was turned off when the alternator output was wired through the C post of the switch that the diodes would fry. I also thought that if the regulator was turned off no damage would occur since the alternator output is still connected, just that the field isn't getting excited for output. In reading this thread, Jeff Tancock, another C34 owner, reported to me that he had OEM alternator output to the C post, his guests turned off the switch, but the alternator survived. Stu ********************************** Jim's reply: Generally speaking the determining factor is just how hard the alternator is pumping at that moment. If it isn't working too hard the magnetic flux in the rotor isn't so great that you get a huge voltage pulse which back biases the diodes to the point they fail. If it is, the flux may be so great that even though the regulator says "cut back, the voltage is too high" there's enough residual flux to cause enough voltage to kill the diodes. Thus it's the luck of the draw. Some of the later alternators have suppressors which limit the voltage spike which occurs under these adverse conditions and some use avalanche breakdown diodes (which are somewhat pricier) that are more or less self protecting. There's a possibility that what he has as well. So far as the regulator being disconnected, you're quite right. Jim ********************** ********************** Since so many people leave their boats plugged in all week, their batteries are fully charged. You said you'd just been running your engine for a minute or so when the literate assistant turned off the switch, so, guess what...
