OK, get this.
After four+ years into my project (1980 37C), I've finally decided to tackle the 115 vAC system. Never mind that the boat came to me with an extension cord (18ga) plug wire-nutted onto the end of the main supply wires (since that had melted off the SP receptical). Of course, I never powered up this configuration!
Here's what I found yesterday while examining main feed into the AC panel:
Green- onto the grounding TS. (That's OK)
White- onto the DPDT master CB. Switched side goes to the neutral TS. (That's Ok)
Black-onto one of the SPDT CBs. Switched side of this CB is the bus bar that poweres the remaining SPDT CBs for other circuits. (Starting to get weird)
And finally, here's what is happening on the second pole of the DPDT master CB: it is fed by the neutral TS (ugh?); further more, the switched side of this CB is tied to the grounding TS (!!!).
To reiterate, I never put power on this system. What I discovered is way off the ABYC norm (as I understand it), and my first thought (biased by the afore mentioned 'extension cord plug') is a grossly incompetence rewire attempt.
Any other thoughts? Perhaps a misguided attempt to accomodate a 'suitcase generator'? My plan is to return the system to normal configuration.
QUESTION: I didn't find any circuit protection from the SP receptical end to the main AC panel. This is a long length of wire. Is protection recommended near the SP end? If yes, would a 30A DPDT CB suffice?
