If there anyone out there owns a 1987 C & C MKIII…I could sure use your help. We have this model and we sail the Great Lakes and winter our boat in Wisconsin. However we live in Nashville, TN. We purchased this vessel in Meaford, ON last summer. So now we want to change her name. So that means new decals. Problem is before I stored her I did not take measurements of the current decal names and available spacing on the hull. The dimensions I need are; the total distance across the stern at the outside top just tightly under the toe rail; The second measurement would be the distance between the (2) small recessed feature grooves on the hull just rearward of mid ships and a couple inches below the toe rail (Only need one side). If I had those dimensions I could order my name decals locally I do have photos of the hull with the current name decals in place, but I can’t determine actual sizes from the photos. If you are able to help…THANK YOU for your time ….Jim & Kathy
