loading
Bill,its prob already done but it is actually very easy, I do this as often as possible with my own boat every chance I get to sail, with a friend helping I'm usually in and out of the water before most of the motor boats around me, sometimes causes curious looks! My trailer is the original float on style for a cat 22 I've intalled a ruuber tire cut in half and bent in half on each side of the keel guide, works perfect and was a cheap modifcation. On my trailer there is a mast holder on the tounge of the trailer I attache a ratchet rope (pulls one way locks the other) if stepping or lowering the mast I lock to the holder on front and just put some muscle into it, only the forward stay and tow front stays need to be re-leased. With help I hook to the forward stay/cable and have some one hoist or lower while under it, a crashing mast is not good as it can bend or cause boat damage. Its not as hard as it looks just give it some thought and two should be able to tackle with ease!Have fun and Happy Sailing!Troy Baker
