Need trailer seal id or part # for 1995 h 26 trailer
Dr D.
Jun 2, 2016
2
Hunter H 26 Tucson
I need wheel seals for my H-26 Hunter made trailer. Vin # 1F9HS232XSA222358. It has 3,500 # axels bearing #'s l44649 & L68149. It has 5 lug 4.5" wheels & the drum cap is 2" dia. I did not measure the dia. of the spindle where the seal rides. Can anyone tell me the dia. or the seal part number? Thanks, Richard S.
Dec 2, 2003
764
Hunter 260 winnipeg, Manitoba
Based on the bearing numbers you give a Google search gives that you should be looking for a 10-19 double lip seal. If you can take the originals in with you to compare. There is a cross reference to a single lip seal but the double lip are better for boat trailers.
Dr D.
Jun 2, 2016
2
Hunter H 26 Tucson
Thanks Twalker,
The Chinese bearing kits on ebay come with the 10-19 seal, must be the most common one for those bearings.
I will have to hope it's the correct one- the boat is 350 miles away in Mexico.
Thanks again,
Richard
Oct 28, 2013
678
Hunter 20 Lake Monroe
I just bought some off of etrailer.com for 1.99 each. I could not find the double lip garlock type seal in town anywhere. If you have to run the single lip to get home I would change them out before too many trips to the water as they just don't seem to seal as well as the double lip seals with the spring on the inside.
Sam
