Need toe/rub rail
20
Hunter 31_83-87 Fairhope
Subsequent to the hurricane damage, the toerails on my '85 H31 need to be replaced. Does anyone know who the supplier is?
Jun 4, 2004
9
- - Josephine, AL
toe rail
Tim: See link for toe rails. By the way, my H37 Cutter (Raven) is up Roberts bayou with a skinned-up toe rail also. Last I heard, the travel lift was out of commission at Pirate's cove. The concrete wall was undermined and will need to be repaired.
Tim Op't Holt
toe rail
I'll pass this info on. Thank You! And, I hope we have slips to go home to sometime in the next 6 months!
Jim
Did mine after Isabel last year
I did mine last year pretty easy job really. I used the toe rail shown on the Taco web site. I ordered the new rails through my marina and they where shiped there 35' long pieces. I removed both old toe rails and filled all the original holes with west sytem and microballons. Then starting at the rear drilled and mounted the new one bending it on as I went. I got a quote from a yard to do it and turned that into my insurance company then I did it myself. Saved big $$$$. You will find that the old stanchon bases will not work. I ordered new ones from Garhauer, I also replaced the stanchons on mine. The total cost for new stanchons was only about $325. If you want anymore info or pictures my e-mail address is jvandyke2@cox.net.
