which appears to have had prior repair on the underside. I get some flex in the floor when I step down from the deck and there is dry crackling sound when I shift my weight from foot to foot. I have drilled small holes in the affected area ( which is about 1 foot x 2 foot) every couple of inches, about 1/2 way through the wood cored floor and injected epoxy, but symptom still exists. I would like to repair/strengthen from the underside and wonder what is the technique for adding laminate to the underside of a horizontal surface, like doing glass work on a ceiling, where gravity will try to deposit everying onto the engine under the cockpit. What about glassing up a 1/4 inch thick plywood or aluminum piece and while wet, bolting it to the underside of the floor to cure, then remove and fill bolt holes? I know I will still need to fill the voids in the existing floor and in the gaps between the floor and the bolt-on sheet, by more injecting from the topside. It seems an aluminum sheet would prevent drilling all the way thru. Also I am trying to avoid stripping off the cockpit floor skin since my past glass work is pretty rough in appearance.Any thoughts?
