K
Kenneth Pfaff
My water heater is leaking and I need to pull it out and open it up to find the problem. But I cannot figure out how to disconnect the water connections. The water lines are all plastic with these plastic connectors. At the connection one part of the connector will turn, but it doesn't seem to do anything. Is there a special trick or is a special tool required to pull off these water lines. Any ideas?
