Buy a small quantity of epoxy
Don, Even though marine tex is epoxy, it has been around so long that this is the name many people use for a quick fix.(Like xerox)I think you will be happier buying some epoxy fairing compound. It works like body putty and is just as easy. Follow prep instructions. If your bottom was barrier coated, sand a bit larger than the damage and coat with barrier coat. If bottom painted, bottom paint to match.I am assuming this is not a cast iron keel. If it is, if you put copper bottom paint directly on the cast iron keel you are enhancing galvanic reaction. (you'll make it rust worse)r.w.landau
