Need the spreaders for 85 Mac 22
Benjamin
I currently came into possession of boat, and learning sailing. Thanks all for a great site. I am missing the spreaders for the boat though. Any idea where i might find, or simple homemade solution to make them? thanks blm
Steve Paul
Aluminum tubing
I believe aluminum tubing will do the job nicely. Find a boat like yours and copy the attachments to the mast and also the stay ends. Steve P.
Mac
Jun 7, 2006
436
MacGregor 25 KEUKA lake NY
Spreaders
If you call the Macgregor plant in Costa Mesa Ca. They will sell you a set for 45.00. I called for my Mac 25 and they have them. You can find thier number at Mac Website. Jerry
bruce
spreaders
spreaders are 12 inch thick wall al tubing, mounting parts prob at dwyer.com or most any other sail supply.
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
BWY
Don't go too thin on the tubing. Once you have the tubing pieces, you can install them with this nice rigid spreader base kit from BWY. They also carry replacement tips in metal or plastic.
Benjamin
Thanks
Hey great. Thanks for all the hints and places to go.
Jan 25, 2005
138
Macgregor 21 Marina del Rey, CA
BWY
I'm also in the market for new spreaders for my 21. I contacted Blue Water Yachts, and it turns out that they sell the spreaders in addition to the rigid spreader bases. I ordered a full set.
benjamin
Measurement?
Anyone happen to have the measurements right off. I do have the mounting hardware by the way. BWYachts is asking for the measurements. I want to see if I can make a pair for myself, what could i use for the end caps? thanks
Steve Paul
Look in West Marine catalogue
Benjamin look in the West Marine catalogue. There are spreader ends of rubber that tape to the spreader and also cover part of the shroud. You could put spreader rollers on each outside end if you run a large jib or genoa to prevent sail damage too. Steve P.
Benjamin
Spreader rollers!
Hey great idea. I had in the back of my mind to somehow work on how to prevent damage because of the big genoa. Will definately go with those rollers. Thanks
Steve Paul
Spreader rollers
Benjamin, Anytime wwe can help. The rollers work extremely well for the money and will save your sails over and over. Steve P.
