Need Swing Keel X-Section Templates
G
Gary
Does any one know where I can get a set of swing keel X-section templates? I suppose I can always go to a dealer and take transfer off of a new boat. Are the swing keels on the MkII the same as the earlier ones?
G
Gary Bordeaux
Keels
I have a fin keel C22. When I faired my keel I generated and plotted my own profile using a NACA 0012 profile. A swing keel uses a shorter chord and I don't know the max thickness so recommending a profile without those parameters is impossible. The MK11 keel is SS reinforced fiberglass and lead. It is possible to retrofit but they cost almost $1000. If you just want to fair your existing keel I can give you some pointers. C22's have a horrible keel shape regardless of which keel you have. Your boat will sail faster and point higher if the keel is faired.
Raul
CD video
Gary, Catalina Direct has a swing keel video that comes with a template for fairing the swing keel to a more efficient shape.
