Your M-18 IS A TRACTOR motor. All Universal engines are Kobuta Tractor engine blocks, which are just marinized by installing a water impeller type pump & zincs. Otherwise there are identical to Kobuta tractor diesel engines. You can save a lot of money on your rebuild part requirements by purchasing the parts from a Kobuta Tractor dealer. You just have to find out the conversion number of a M-18 to the Kobuta part numbers, which may be in your engine owner's manual. The marine specific parts such as the heat exchanger & water pump & exhaust risers can be purchased from Westerbeake, who now owns Universal, but their parts are very expensive. I usually always feel that rebuilding what you've got is always cheaper then replacement, unless the block is cracked or extremely corroded. Its also good to know that your engine already fits in the existing motor mounts, & you can re-use your existing transmission & shaft set up, which is an expensive thing to modify, when you change engines, that most sailors never seem to factor in before they commit to an engine repower. Good luck on your rebuild.
