Removable masthead on 28.5
On my 86 28.5, the mast was a Kenyon and the masthead was removable. Rig-Rite out of Warwick, R.I. has an excellent web site and you can probably order one from them. Good LuckFor your info Ed, on my current boat (84 H34), the mast was also a Kenyon with a removable masthead. I had to replace it and Charleston Spars who are a current supplier to Hunter makes one that needed very little machining on the deck plate to install. This new one has a heavy cast welded masthead with a removable plate on top for access to the inside of the mast if needed.
