Need insight on boot stripes
McZube
Apr 5, 2012
119
Hunter 31 Chesapeake Bay, MD
1) What's the purpose of a boot stripe? Is it to provide a durable scrubbing surface at the water line? Is it for aesthetics so that staining at the water line will be less noticeable?
2) Where should the boot stripe be placed? Just above the water line? At the water line? Straddling the edge of the bottom paint at the water line?
3) If WM doesn't have the color I want for the boot stripe, what's another source of polyester paint for this purpose?
Thanks.
Nov 24, 2012
586
Today I think it's primary purpose is aesthetics breaking the hull color. My boot stripes (last four boats) have been between 3/4 and 1 inch above the waterline.
Enamel was used to paint and touch-up the stripe. Interlux paint available through most retail outlets.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I purchased some "boot stripe" paint. It came in an 8 oz can and I've done our San Juan 28 twice with it with enough left over for a 3rd. It's Interlux Brightside polyurethane with Teflon. It was marketed specifically for that purpose. I got it at Harbor Marine in Everett Wa, but it can't be unique to them.
Ken
Mar 1, 2012
2,182
aesthetics mostly,, but many many cruising boats (Including me) have done away with the boot stripe, since most are loaded variably, and often that boot stripe is under the water line, particularly when first leaving on a cruise-grin
RichH
Feb 14, 2005
4,773
Thanks.
The aesthetic portion, as with cove stripes, is to create the optical illusion of 'longer boat'.
The functional aspect is to create a contrasting color which hides all the tannin stains, scum, etc. that usually form from the water lapping above its normal resting plane. So you dont have to continually wash/scrub off all that 'dirty toilet bowl' looking stuff all the time.
If you cant find the color you want go to a LOCAL dealer, who also paints boats, to have just about any color 'tinted' to what you want.
Best place is from the water line 'up' to where the normal waves are topping off, or to where the 'white' isnt 'grimy' looking. 'about 3 or 4" on a 30 ft. boat should be 'close' for asthetics. BUT dont get too carried away as once you PAINT a bootstripe, you'll be forever painting that bootstripe unless its a bombproof 2 part LPU urethane, etc.
-na -NA Anywhere USA
I use to purchase stripping from specific automotive paint stores when I could not find them; otherwise for the oddball colors customers wanted, I went to those who made the decals.
crazy dave condon
Jun 16, 2004
18
Beneteau Oceanis 461 Kiawah Island, SC
The boot stripe may be only cosmetic, but when approaching a boat in the water, you can quickly identify if that boat is below "it's normal water line" indicating full bilge or other water/weight on board!
A walk down the dock and seeing no waterline indicated can allow your neighbor to call you, or possibly start pumping rain water out of your boat for you.
We have called this bottom paint, and realized the boot stripe as being near the toe rail, not the water line. What is the correct term for these two painted areas?
Jan 9, 2013
76
Hunter 27 Mooresville, NC
It can be a little confusion. Here's what i learned while stomping around the boat yard, spending cash faster than 3 priests at a stripper convention:
The "bottom paint" generally only refers to the paint ( solid color) from the bottom of the keel up to the waterline, or just below it. Just above that bottom paint ( usually 3-4" above) is where the boot stripe can be found. Above that boot stripe is sometimes another stripe, usually just referred to as a stripe, or a topside stripe..maybe a cove stripe? For some reason, the area above the bottom paint and below the deck is called the topside; even though is isn't ..umm...on the top. I've found that good scotch helps to decode sailor logic..:)
Jun 9, 2008
1,792
- -- -Bayfield
Many, if not most, production boats, have a score in the gelcoat (from the mold) that shows the designed waterline. It is easily found on new boats, but sometimes impossible on used boats. You can easily tell the real waterline on a boat that has been in the water if it reveals a water stain. That can be your gauge. Waterline stripes are cosmetic. You can be as creative as you wish and can afford. Some boats have triple stripes of different colors even. Some a thin single strip and some a much thicker one. Some have a thick one and a thin one. It is up to you, but depending on the hull shape, shear, etc. a stripe can really make a boat look a lot better. Boats that dry sail/race often have a completely white hull and the owners like that look. Not so frequently boats that need antifouling will apply the antifouling without a waterline stripe. This, in my opinion, looks better on a one design boat, but it is all up to you. The problem with vinyl tape is that the tape is the same dimension from start to finish and if you look at painted on (or in the mold - gelcoat) stripes, you will see that the thickness varies with the turn of the hull at the waterline stripe. The bow will be thicker, midships will be thinner and at the transom the thickness can be 3 or 4 or more times thicker depending on the run of the hull and the size of the transom and where it sits in relation to the waterline at the stern. Vinyl stripes are easy to apply, while paint is more difficult. But, like anything, more work usually produced a nicer look. If you are going to use paint, then I would stay away from polyurethanes if the stripe will be submerged as it will blister. Paints like Awlgrip are great for above the waterline where is is temporarily wet, but not constantly submerged. If under water the entire time, it (along with Imron and other polyurethanes) will blister. So, while it is used above the waterline all the time, it is applied above the waterline. The antifouling can meet it, or you can put a white (or whatever color your hull is) space between the waterline stripe and the antifouling. It is all in the cosmetics. Interlux makes waterline paint (called bootstripe) in basic colors (navy blue, black, white and red). It is good because they sell it in small cans and you don't have to buy a quart of paint to do a small stripe on a small boat, for example. You can buy a laser beam device to use as a guide to make sure the waterline top is level (the boat has to be level too) when the boat is on the hard. Or, with some help, you can stand back with a step ladder with a 2x4 on the top, leveled off and eyeball it at the level boat and guide someone to make a pencil mark at the right spot along the hull defining a straight line. The straight line will not be straight on the hull, but will look straight from a distance even though the hull is curved at different places. A harder way of determining a straight waterline is to use a clear hose filled with water. Supposedly water always finds its own level, so keep the ends of the hose above the water line of the boat and the water level at each end should be the same and so then you can determine the this position anywhere on the hull. This sounds easier than it really is, however.
Catalina 320 Dana Point
Like Mac I use the boot stripe on my boat and others as a trim reference, 2 identical boats to mine nearby sit much lower on their lines. That's a good thing to me.
If you are "bow down" the boat will tend to "gripe" (want to wander back and forth), too low in the stern may slow the boat and make steering feel a little loose.
Cove stripes are pretty much decorative, I removed mine to replace and decided I liked it better without. Want to buy two rolls of cove stripe tape ?
Sep 26, 2012
3
Beneteau 373 Toronto
Thanks.
In the case of my Beneteau 373, there is so much freeboard the boat looks ungainly, the bootstripe breaks up the profile to look almost normal. Having said that, it was the worst product application I have seen from Beneteau but that's another story. Can't think of any useful function other than aesthetics and maybe a bit easier to clean at the waterline.
May 30, 2006
348
Oday 34 Chesapeake Bay
From the waterline up, Karma started out with a 1 inch blue strip followed by a 1 inch white stripe, then a 4 inch blue strip against the white hull. The 1 inch stripe was constantly fouled so when I re-barrier coated her I got rid of the two 1 inch stripes and lowered the 4 inch strip to meet the bottom paint and have been much happier ever since.
Good to know that it's a fashion statement and I didn't commit a "party-foul".
Oct 15, 2012
14
Venture /MacGregor V 222 Zephyr Cove, NV
Boot stripe was originally used to level out the top of the bottom (anti-fouling) paint as when it was applied it was less than perfect with regards to lines, meaning a bit wiggly and not a clean crisp straight line around the boat. For commercial boats (fishing etc) it wasn't a big deal if the lines resembled a coastline instead of an interstate. My fathers boat (com fishing) was lucky to have the same color as sometimes it was use what was available with little regards to what it looked like (it was a tool to catch fish, not a feature in boat parade).
Boot stripes on private boats & yachts was asthetics, as stated, but mostly due to boatyards (in the day) not paying particularly great attention to their edge of bottom paint meeting the hull (no anti-fouling paint). Additionally, in the day, the choices of color was limited to red (barn red/brown) or black. Only in the past few decades has the color pallett exploded with multiple hues to choose from. That's my 02 cents worth, having grown up in a fishing family.
DougMc
Hunter 36 Erieau Ontario
Boot tops where originally placed at perfect boat trim and displacement. Let you know if you had too much beer on board. Personally I relocated boot tops 6" higher, keeps crud off boot. I have had good luck using automotive adhesive strips.
Aug 24, 2012
50
Sailstar/Bristol/Herrshof Courier 26 Kemah , TX
Like "wednightracer" said stern area is always more or less a nightmare to do, and as "tahoemac" pointed out my grand pappy commercially fished of Australia and the color of paint was completely irrelivant! The purpose was to keep the hull somewhat , or better protected from the seas wrath, and also as many have pointed out to provide a visual gage of overload condition, however on that note , some commercial owners have been found to paint the waterline LOWER than the water really IS ; to Phyche the other owners ,to believe he , they , always catch more tons of fish than anyone else, so fair winds and good currents on the bloody lot of yas, eh?
Dony; master , s/v Pretty Girl
Jan 13, 2009
394
J Boat 92 78 Sandusky
Another option is what I used on a a boat I used to own. The previous owner had painted a boot strip over the original faded colored gelcoat stripe. Let's just say he wasn't exactly a craftsman. I sanded the bootstripe paint. Rolled and tipped 2 coats of boot stripe paint and then used a 1/4" vinyl pinstripe on the top and bottom of the boot stripe in another color. It looked sharp and lasted for several years.
One tip about painting the bootstripe is to use 3M fineline tape or a stretchable 3M super 33 electrical tape when masking the stripe. Regular masking tape doesn't work well in this application.
