JERRY
neogating purchase on 1982 cat30 made offer of 12,000 with mechanical escrow of 1,200(only for the engine) at time of offer we were aware the hull had blistering and the rudder was leeching rusty water and a leaking hatch. The survey reveals multiple problems need advised1 The engine as a milkly oil level almost three inches above fill mark on the dipstick.(mixed with water)Found out from the broker that the engine, as been this way for over a year. Cranked engine one revolution not seized, broker feel like 1,200 escrow will cover repairs to water in oil problem, broker said if compression is ok engine will be fine once water problem is fixed???? What about corrosion???? 2 discolortion on port side of engine head(probably related to head gasket failure or over heating????)3 cooling line existing exhust manifold runs up under sink into bronze U and back down to muffler, another line T's off of bronze U going up then back down and dumps into bilge????(Would this dump hot cooling water and exhust fumes into biges???)Surveryor did not understand why it is ran this way. Does anyone know??4 Toilet base is cracked and caulked, can parts be order? It is the original.5 Bilge and cockpit drain ports have a clear vinyl tubing sticking out from port down to water level. How do you get access to plumbing under cockpit?6 Roller furler,165% ginny,- baot is demasted steel cable protruding from spooler on furler it has no hardware only frayed ends?? Fuler has heavy stainless steel guide around it which has been broken and rewelded, did not see any name is this cat30 optional original equipment? I do not know anything about roller furlers. Surveryor did not know either.any help on any of these problems would be appreciated. Especially on the engine repairs. Being done without a total rebuild. This is our first sailboat excuse our ignorance's. thanks so much
