Need info on shore power options
Todd McCormick
I recently purchased on 1985 Hunter 25.5. I'm thinking about changing the power configuration a bit. Currently, there are 2 batteries on board. One is connected, the other is kept charged as a backup. I plan to install a switch this weekend to allow me to use either or both batteries, which will make things more efficient. However, the boat is not equipped for shore power, and I would like to find out what is required in terms of materials and cost to set that up. Thanks!
Marc Honey
Go solar
I'd install one of the solar chargers available. Used to have the square one (approx.13" sq.) that put out 5 amps I believe. With 2 batteries and the ability to switch between them, you should never have any problems. Had this set-up on my old 23.5 Kittywake and sailed for 3yrs. or more without touching the batteries. Lots of night sailing,lots of stereo, and an electric bar (windshield washer jug w/ motor and tubing coming out the faucet in the sink!!!)...no problems.
Michael Cohn
Required Things...
I would think that a small marine battery charger, a shore power cord, a shore power outlet on the outside of the boat, an AC breaker, and some wiring to the charger and batteries should do it for you. In theory, you can do all of this yourself, but AC can be dangerous and unless you *really* know what you are doing, I would have a professional do the wiring. MC
Stan Duncan
Solar Panel
I agree with Marc. Ihave a 12" x 18" solar panel for my h25.5 and it keeps the battery charged fine. The biggest battery drain is engine starting - if you don't have electric start solar charger should work fine. Wireing a boat for shore power would be a MAJOR operation.
