need info on main a/c breaker (120 volts)
danny
the main breaker (a/c 120 volt) in our 1981 H-30 is showing signs of age and does not always stay in the "on" position on the first try. It is a 3 pole single toggle switch. The numbers on the side are "8034" UPG666-4094-1 cust. P/N 3000040022. It was made by Air Pax. Tried WM, they only have a 2 toggle switch which will not fit the panel holes. Any suggestions?
Jun 2, 2004
5,802
Blue Sea?
You might try Blue Sea. I have found some unique products at their site(Related Link). I am surprised that your AC main is different from mine(1979 H37C). My breakers are all the same physical size and shape, both AC and DC. They fit the dime size hole in the panel. And they are simple single-pole/single-throw. The main simply supplies 110V to the bus bar. Then I have four c/b's below that for outlets, etc. Cannot understand why yours would be different.
