Need info on control module for AB cooler
Dan Dickey
We have a boat that was salvaged after a sinking. Most things are ok but the refrig. unit blows the 15A auto fuse. I replaced the fan but there is a black plastic housed control box (holds the fuse) that feeds the compressor and fan. It has a few "faston" terminals (fan and temp sensor) and a 4 wire cable that plugs onto the compressor. We suspect the board inside this control box and/or the compressor is/are bad. Is there any way to tell which is bad? Also, are there any resources that will tell us the model/part # of either the control box or the compressor and where we can get replacements? Best regards, Dan
SCOT
CONTROL MODULE
THE CONTROLE MODULE IS MOST LIKLEY SHORTED OUT AFTER GETTING WET. I WOULD LIKE YOU TO FIRST OHM OUT THE FOUR PINS ON THE COMPRESSOR. THE BOTTOM PIN IS COMMON, OHM OUT BOTTOM PIN TO RIGHT PIN =.2-.4 OHM, BOTTOM TO TOP =2.4-4.5 OHM, BOTTOM TO LEFT PIN = .2-.5 OHM. IF YOU GET THOSE NUMBERS THE COMPRESSOR SHOULD BE OK. THE REPLACEMENT MODULE IS A # AB3016 WAECO USA. CUSTOMER SERVICE 860-664-4911
Terry Cox, Hunter 42, Belle-Vie
Scot, I'm assuming that the ohm readings are...
taken with no power to the unit? Terry
SCOT
MODULE
CORRECT NO POWER TO THE UNIT. REMOVE THE PLUG FROM THE PINS AND OHM OUT THE PINS ON THE COMPRESSOR.
Apr 13, 2004
3
- - Havre de Grace, MD
See this Great Site
I Got a new compressor from these wonderful people 2 years ago...what a great technical resoure, fast service, and good prices. Check out Rparts.com
Scot, I took the compressor ohm readings...
the correct way and they were as follows: First base was .3 then it dropped to .0. Second base was a solid 3.4. Third base was .3 then it dropped to .0. The unit starts right up after resting for awhile, then when it recycles the fan comes on, the compressor attempts to start, then a high frequency tone for a second or two, then the fan comes back on. If I shut the unit off for ten minutes it starts right up and runs until it cycles again. When the control module is unable to start the compressor under normal operating conditions, it will start if I thump the compressor dome with my fist a couple of times. We've talked on the phone a couple of times and you seem pretty sure it is the control module. Based on the above do you still think it is the module? Terry
SCOT
MODULE
LOOKS LIKE A NEW MODULE WILL DO THE TRICK CALL WAECO USA @ 860-664-4911
