My 23 is on an old powerboat roller trailer...
The PO bought the trailer, then cut the rollers off with a torch, added a carpeted keel board down the center, then added the needed height to the rollers by putting 2 steel plates inside and out to extend them up. He used one bolt at the top and one at the bottom of each roller allowing them to move a bit when loading or unloading the boat. The plates flex just enough to take some of the bounce out of going down the road. About 70% of the boat weight is on the keel and keel board, the rollers take the rest. The dual axles were centered under the keel a bit to balance the tongue weight.
When I bought the boat, I seriously thought about going to bunk boards, however once I launched and retrieved the boat a couple of times, I realized I could pull the boat onto the trailer without putting the whole trailer under water, it rolls up on the rollers and slides along the keelboard. No need for a tongue extension or a truck equipped with a snorkel. I'm very happy with my trailer this way.
I don't have a pic of just the trailer or a shot that shows that much of it, I'll try and get one for you.
