I bought a % of charge DC Voltmeter and would like to use it to read both battery banks (instead of buying two expensive meters!). I figure wiring the +/-leads from each battery to a switch then wiring the switch to the meter should do the trick. I assume the switch would have to be a DPDT (on-off-on) with 6 spades on the bottom. Wire one battery to one side, the other to the opposite side, the switch to the middle contacts, correct?Also, the meter requires an inline 1-Amp fuse on the + lead. Should I wire a fuse on the + lead from each battery to the switch, or is one fuse on the + lead from the switch to the meter sufficient? (Seems like it should be...) Thanks for your help!
