Need help with replacing the felt on my Hunter 260
G
Gina
The felt on the inside of my Hunter 260 needs to be replaced. I don't want to replace it with felt. I would like to put wood up instead. I would like to know a glue that is water and fiberglass friendly. It will need to adhere the wood to the hull, just under the window, to the bow of the boat. I can't use nails, there is no space between the hull. Please Help if you can. Thanks
