need help with engine h27
13
hunter 27 1981 Charleston
Im trying to rebuild my Yanmar 8 hp from my 1981 h27, does anyone have the manuals and where can I get parts for it?
Thank you
Dec 8, 2008
96
Hunter 27 Deale, MD
Torrensen is the place to go. You will want both the manual and the parts catalog as well. The manual does not list the part numbers. It also does not hurt to purcahse an after market manual as well. These will give you a little different take on how something is done.
I have the same boat and engine and they are a blast to re-build. Just remember that you will need all metric tools. And it is also easier to do the work if the engine is out of the boat. That way you can get to every part and you can even bench test it once you are done to make sure it works before you put is back in the boat.
Dec 2, 1999
15,184
I believe that Mack Boring is the master distributor in your area.
Yanmar Dealer/Distributors cannot sell genuine Yanmar parts outside of their territory.
