Need help separating shaft coupling
362
Hunter 30 Smithfield, VA
I have a 70 Hunter 30 with a Yanmar 3GMD. Failed in my first attempt to check engine alignment. I was able to easily remove all four bolts in the coupling, but the two halves would not separate. Looking for recommendations for good method to separate the halves. I made a few cursory attempts to drive them apart but didn't apply much force and quit while nothing was damaged and I can still go sailing Sunday (our first Pagan River race of the year).
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
shoot it up with "PB Blaster" for a few days.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
With two equal weight hammers strike opposite sides of the coupling at the side time. This procedure can break almost any tight fitting loose and not transfer any undo load to the shaft. The trick is to make the strikes simultaneous.
Oct 29, 2005
2,366
could it be your packing gland is tight? what about barnacles on shaft? maybe you were trying to push them into the cutlass? it shouldn't be difficult to split the two couplings.
May 21, 2009
362
Thanks for the advice, I'll give the PB Blaster a try first, then go after force. Yes, I too though they should just come right apart, but there wasn't the slightest movement whatsoever, so the halves are clearly coupled together. I wondered if there is some sort of centering flange or something contributing to the fusion.
