Rick Evans
I just attended a marine electronics class. The instructor stated that shutting off the key does not hurt the engine. It only disables the tach and the alarms but, contrary to popular belief, does not blow out the alternator because it is still able to discharge into the batteries. Yet, the boat manual for my Beneteau 321 with a 27 HP Yanmar 3GM30F warns in bold print never to shut off the key without first shutting off the engine. Second, the instructor also said that at dockside, you could start the engine and run it even with shoreside power running and the battery charger working. Yet, the boat manual warns in bold print never to start the Yanmar with the battery charger working. I presume they think it will overload the batteries or do something evil to the alternator. Yet, my instructor said the batteries don't care where they are getting a charge from. If the alternator senses the charger has topped off the battery, the regulator will simply shut off and the alternator will be happy. Any thoughts on these two issues and the different pieces of advice on got on each one? Thanks.
