Juan
Hi:i don't know enought about Capri 14.2s and I am looking at one now that is for sale. I am guessing that it is a version 2 of this boat from about 1990. This is the Capri 14.2 with the small insert storage compartment.My questions:On the right seat there is a hand hole that has been installed. I opened it and inside are several 5 gallon jugs. I asked the people who own it and they knew nothing. one theory is that it is the flotation. I doubt that but could it be? Then why is there no hand hole on the other side. When the boat was out of the water, I removed the drain plug at the back of the boat which would drain the inners of the boat. A bunch of water came out. i think all of it. We put the boat in the water for about 30 minutes (not under sail) and afterwards even more water came out of the drain plug. how is the water getting in. when I checked the hand hole noted above. There was the water.The centerboard seems to have as its stop mechanism when it is in the down position a stainless steel bolt that just lies across the centerboard opening and on the deck. Is that it?I have only owned large boats, never a small one and definitely not one with a centerboard. When in the water, i have to assume it is typical that water is present in the centerboard well about 2 inches below the cockpit deck. correct?What else should I be checking on this boat. didn't get to see the bottom.This boat was owned until recently by a sailing school and the 13 year boy who is an instructor bought it a couple of months ago and now just wants to get rid of it. price is only abotut $700thoughts???thanks
