VMG, other terms
VMG, or "velocity made good" is speed made in the direction of your destination.VMG is important when the boat's nose is not pointed directly at your destination, which occurs:1. On a beat. The direction to your destination is in the no-go zone. You might ask yourself, "is it better to pinch, go slower, and point more directly; or is it better to bear off a bit, go faster, even though it means going a little farther?" The answer is: whichever method produces the highest VMG.2. On a run. You could point the boat directly at your destination, but what if you could get there faster by gibing from one broad reach to another? VMG again gives the answer.On a reach, you're already fast and you're heading directly at where you're going. On a reach laying your objective, SOG and maximum VMG are the same.Your GPS can only calculate VMG if it has a destination, i.e. you are sailing to a waypoint.If you're a trigonometry whiz, VMG is roughly SOG X cosine(Heading - Bearing), or something like that. SOG is Speed over Ground, Bearing is the bearing to your destination, and heading is your wake course.I think it's tough to get this information from a GPS, unless your helmsman is very skilled at holding a course long enough to measure VMG for a given wind angle. That's why people tend to use polar diagrams instead.Some other definitions:1. Average speed: probably the average speed from the moment you turned on the GPS, or the moment you started your route, until now. 2. Moving average speed: your average speed over the last X seconds, X being determined by the person who wrote the moving average calculations into the GPS's software.It's a lot of stuff, hope it helps someone.Paulsv Escape Artisth336
