John North
While cruising at 2500 - 3000 rpm in choppy water - the Yanmar engine hestitated, lost power and eventually staled. I switched off and after a half hour was able to restart. I ran at 1000 rpm and was able to limp back to the dock.I suspected a blocked fuel filter and did indeed find sludge in the bottom of the filter which is located under the berth in the stern. I replaced the filter and cleaned the housing which of course caused emptied the line. I changed the smaller filter too even though it was relatively clean.How do I prime the filters? Is there a filter on the pickup in the fule tank?I have worked at it all day and am defeated. Any suggestions?
