supercool
On the other hand, the Supercool units, made in Sweden, draw only about 1.5 amps (measured), have two little fans, and draw cool air from the bilge to cool the heat sink. The ducting is standard 4" stuff you would use for a dryer. On my boat, the exhaust goes into the cabinet under the sink, helping dry things like pots and pans. The original fans, very easy to replace, would last almost exactly two years. The new ones are supposed to go four times as long. Mine have about six years on them, so far. I live aboard, by the way, so the refer is in constant use. I have been using this system since 1986, and it is very economical and reliable. The little unit, good for up to a four foot box, reasonably well insulated, is an easy install, and is as close to a no-maintenance unit as you will find. It is not a freezer, but it is a refrigerator.
