Need forestay length for 1983 TM Hunter 27
K
Keith Fawcett
Hello you all, Does anyone know the length of the forestay for a 1983 Hunter 27 TM? I appreciate the help. Cell: 985-285-0310 ALl the best to all, Keith
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
What's the difference between a 27 and a 27 TM?
What's the TM stand for? Twin mast? Manny
Jun 2, 2004
5,802
TM = Tall Mast.
A Twin Mast would be a ketch or yawl or even a schooner. :) Not sure why but both Hunter and Catalina had tall mast versions of their 27s and 30s and maybe even bigger boats. The site that I reference has dimensions for a tall 30 but not the H27(Related Link). Does anyone know, was it just the full keel boats that had tall masts?
Manny
Oct 5, 2006
983
Tall mast?
Ed, I thought the 27's of that era all had the same sized mast, roughly 36.5 ft long (+- 39 ft from the waterline). I thought these were just considered a high aspect rigs... My mast is this height and is as tall as rigs on many 30 footers. I have a shoal keel on mine also. Anyway I may have my old forestay in my basement. If I find it I'll measure it and post it on this thread. Manny
May 24, 2004
7,190
CC 30 South Florida
Manny is right the 27' Cherubinis all came with
the same size mast. The key word is came as if from factory; over the years some of these boats may have been re-rigged so it would be advisable to measure your headstay and not use stock figures. The tall rig classification of the h27 was a name marketing ploy as during those years tall high aspect sail plans were in vogue. Some manufacturers offered both a normal and a tall rig but Hunter deside to not offer the normal. Can there be a tall rig if there is not a normal? I guess if you compare them to the competion normals it makes it a tall rig. They were designed to be the least expensive production 27 in the market and they built one heck of a versatile boat.
Manny
Oct 5, 2006
983
Keith - 38 feet 2 5/8 inches
At least that is what my forestay length is (give or take roughly and eighth to a quarter inch). Tonight I measured the one I had replaced last year. It was measured from the center of hole for the pin at the mast head to the end of swaged fitting for the turnbuckle at the bow. I don't know if it was the original forestay since my 27 has a CDI furler on it, also I do not know if there were any modifications made to the rig at any point. At least it should be a good starting point to get an estimate on cost. Hope this helps, Manny
Jun 5, 2004
160
Hunter 27_73-83 Harrington, Maine
Keith
I have one off and will measure tonight. If its the same as Mannys you should be OK.. Interesting about the tall rigs Randy
Jun 5, 2004
160
Well...
I checked the forestay on my 1976 H27 and it was 34-11" from the center of the eye to the end of the bow turnbuckle thread - maxed out with the turnbuckle fully extended would be know more than 35'-8". My mast is 33'-1" long. Seems there may have been a change in the later models. Randy
stephen
my 27 has a tall rig
My 79 h27 has a tall rig compared to other h27's
