Need details for reconstructing keel guide on H-23 trailer
5
- - Lake Thurmond, GA/SC
This is a 1987 vintage Kens Welding fabricated trailer for my H-23. The plywood base has rotted away and I need to reconstruct this along with the keel guide stubs that were there. Does anyone have templates so I can properly size and locate the keel guides in the correct position, spacing and angles? Anyone with a functional trailer like this can provide some measurements. Much appreciated.
Brian M H23
Give me a little bit
Theres one in the boatyard. I can take some pics for you (My 23 has a centerboard and no wing, so my keel setup is probably different)
Louis
Nov 21, 2007
56
Hunter H23 Verplanck, NY Hudson River
I have a 1986 Magic tilt trailer.
If this is the one you want, let me know and I will take measurements and pictures for you tomorrow
Jun 3, 2004
232
No need...
I have the same trailer and replaced the plywood two years ago. I put some outdoor carpet on the marine plywood mostly to just make it look a little better. The keel stub can be more of a problem than it is worth. As you haul an H23 out of the water the hull can't come any farther forward than the winch so you don't need the stub to stop the keel, but if she isn't quite centered the keel can sit on the stub and you have to back in again and work at getting her centered. Without the stub she can be an inch or so either way and sit just fine. I'm happier without the keel stub.
May 22, 2005
6
- - whiskeytown.ca
TRAILER
I HAVE A KENS WELDING SERVICE TRAILER, FOR 1987 H-23 WING KEEL. I WILL SEND YOU PICTURES TODAY. BLAINE
