Need Bottom Advice
12
Mac 25 Half Moon Bay for crab season
What's the right combination for my boat, what primer, what paint
-just repaired many blister's
-usually on trailer
-may be in saltwater up to three weeks at a time
-may eventually be in fresh water slip year around
-material has to be California legal
Joe
Jun 1, 2004
8,257
Ablative paint, if the boat's going to be out of the water alot. Read the westmarine advisor.
Mar 16, 2009
12
I've read that, several other articles, and a bunch of internet forum threads, I was looking for brands etc... I would like to save a couple $ and buy west marine brand but not if it will have me back under the boat soon
higgs
Aug 24, 2005
3,715
Nassau 34 Olcott, NY
I think your best bet is to see what others, who keep their boat in the same lake, are using and go with that. Others here would know better about the salt water, but I don't think 3 weeks with the wrong paint is not going to be a problem. For one thing, if you are on holiday at the ocean for 3 weeks, it is likely your boat is going to get used a lot, which will help keep growth at a minimum.
Feb 6, 1998
11,722
-usually on trailer
What was the product used to repair the blisters? Was it vinylester putty, polyester putty or an epoxy based putty? If it was a polyester type of filler you will want to seal it with an epoxy or a barrier coat as polyester "Bondo" type products can absorb moisture and after ding all that repair you probably don't want that.
If it is only going to be in the water a max of three weeks you might not bother re-painting the bottom and instead just sealing it with a barrier coat product like Interprotect 2000E. If you really must paint a multi-season, haul & re-launch capable ablative is the way to go.
Mar 16, 2009
12
Sweet, I was looking at the 2000e and the 3000, Anyone know the difference?
I was on the fence about using anti-fouling paint but the boat's up and sanded now so I thought I may as well.
For the paint I was looking at the Micron extra, West Marine Brand, and a couple others.
Joe
Jun 1, 2004
8,257
3000 is epoxy barrier coat........... 2000e is primer to bond antifouling paint to epoxy.
from westmarine site: re: interprotect 3000
Microplates® act like shingles to prevent water absorption
High solids, VOC compliant epoxy with Microplates®. Can be used down to 32°F. Use Interprotect® 2000E as tie coat prior to the application of antifouling paint.
Mar 16, 2009
12
So I have to do both 2000e and 3000? You wouldn't happen to have a link to that westmarine page it sounds like just what I need to read. I'm going to call interlux tomorrow.
Feb 6, 1998
11,722
Joe,
Both 3000e and 2000e are epoxy barrier coats. Most every boat yard that does barrier coating uses 2000e. 3000e has a wider temp range, is more VOC compliant and was originally intended as a spray product though it can be rolled.
With a roller 3000e goes on slightly thick and does not leave as smooth a finish as 2000e probably due to the higher solids content. I've rolled both products and prefer 2000e if you can guarantee the temp won't dip below 50f. 3000e is thicker and usually requires 3-4 coats to get to 10 mils (2000e takes 4-5) so sometimes less coats are needed but it also goes on a little sloppy. If you want a smooth bottom 2000e is the way to go IMHO, but both will work just fine....
Joe
Jun 1, 2004
8,257
Maine.... thanks for your comments. Those product descriptions can be misleading. I read both the 3000 (not 3000e) and 2000e overviews and it appeared that the 2000e was used as a primer, or tie coat, to chemically bond antifiouling paint to 3000 (and other surfaces, too). Your response allows me to consider the 2000e as a stand alone barrier coat and since it's cheaper than the 3000 I thank you.
By the way, here is the product description for 2000e as it appears in the WM site.
Universal above- and below-the-waterline epoxy primer
A high build universal above and below waterline epoxy primer for all surfaces. Fills severe cracks and crazing in gelcoat. Adheres well to properly sanded bare metal. Offered in gray, or white, which is excellent as a topside primer.
  • Total Thickness Required: Above waterline: 2 coats; below waterline: 4-5 coats (10 mil minimum)
  • Drying Time: Overcoating: 3 hrs. to 2 wks @ 60°-80°F.
  • Coverage: Brush: 60sq.ft/qt., 240sq.ft./ gal.; spray: 45sq.ft./qt., 180sq.ft./gal.
  • Application Method(s): Brush, roller, airless/conventional spray Thinner: Interlux 2316N, Model 198598 (10% reduction limit)
  • Quart or gallon
544
Bristol 43.3 Perth Amboy
Paint Selection
Not all paints allow you to remove the boat from the water and replace while maintaining activity. Choose carefully. There is a difference in some fresh water vs. salt water paints. I'd choose the paint that met my immediate need. If you did an epoxy job on your bottom, you will need a specialized primer prior to bottom painting.
Mar 16, 2009
12
from interlux tech sservice
Good Morning Joe,
I would recommend applying InterProtect 2000E as a barrier coat followed by Micron Extra VOC as the recommended bottom paint. I have attached both the InterProtect Bulletin and Micron Extra VOC datasheet for your reference.
Regards,
Jay
What's the right combination for my boat.
-just repaiered many blister's
-usually on trailer
