Need advice on installing a Simrad 10 Tiller Pilot
H
Hayden
I bought it but now am not quite sure how to install it to maximize its performance and minimize the use of space in the cockpit. Has anyone put and auto tiller on a 23.5? Where is it attached to the cockpit? Starboard lockerlid over the gas tank? To the side of the cockpit below the locker lid? Help!!!!!!!!!!!! There are no real instructions! They imply that all boats are the same. Any tips on istallation will be appreciated. Also, did you wire direct to the battery or throught the electrical panel? Thanks Hayden
Tim Paul
Put Mine on the Cockpit Floor
I'm not familar with the 23.5 but on my h26 I installed the mounting post on the floor with the tiller bracket underneath the tiller. This location pretty much out of the way, doesn't take up seat room, and works very well. I got the idea from the archives which had a lot of discussion on mounting options. If you haven't checked there yet, you should. Be aware that they make different tiller brackets and (I think) mounting posts to fit different needs. The install isn't too tough once you find the right location. I wired mine direct to the battery with an in-line fuse and haven't had a problem. I checked with the Simrad technician before doing this and they said it would be fine. One more thing I found useful was to "temporarily" mount the tiller bracket with a heavy duty hose coupling clamp with rubber inside until I got the location just right. (I got this at Home Depot.) If you have a wooden tiller, this may be less of a concern but mine is aluminum and I didn't want to drill holes until I was absolutely sure. Do it right and you'll have one of the best upgrades there is (IMHO). Good luck.
Mike B
Let me know ,please...
Please let me know when you attach the auto pilot as I would also be very interested in obtaing one and I am curious as to how it can be mounted so as not to interfere with the motor operation or swim ladder. Please let me know how you make out with it . Thanks !
