I have a 1995 hunter 430 with no generator (I do have a honda 2000 generator with shore power adapter). I am running the basics, microwave, TV/DVD, and refer. I have the standard, factory installed, Heart interface inverter. I have two 8D, 6volt, centennial deep cycle batteries (purchased in Jan 07). I have a starter battery also.
One of the batteries is not holding a charge well. I know I need to replace that battery.
I have a few questions for all of you.
1, What type of batteries should I Buy (Standard deep cycle, Gell, AGM)? I Know the Gell or AGM are the best but are the worth the money?
2, If I replace battery with another deep cycle should I replace Both?
3, The inverter shuts off at 10.5 volts, is that when it should?
4, It seem to run the inverter hard with the refer on. Is that hard on the inverter?
Thanks for your help!
