need a lift and load and unstep the mast in west florida
446
Catalina 400 mkII Harbor
the boat is in cape coral right now and i am going to truck it north. i will take all the sails down and help with the mast. i am looking for a affordable yard. the one price i have is 240 to lift and load plus powerwash (40 foot) and 380 to unstep the mast, i think the lift is fair but the mast seems high, in chicago it would be about 200 to unstep. thanks mike
May 17, 2007
180
HUNTER 25.5 St. Augustine
unsteping mast
As a reference, at our marina at Herrington Harbour, just south of Annapolis, they charge $125/ half hour to unstep the mast. See their work order sheet. Good luck.
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
Mike We've pulled a lot of masts at clubs I've been at, and
find it"s not too hard to do between two boats with Spinnaker Halyards (that is if you do it while the boat is still in the water). It's harder to do if you have double or triple spreaders, but single spreaders are normally slightly above the mast center of gravity. If you think the spreaders are close to the CG, add a little bit of weight to the base of the mast. It just requires a rope loop (with a retrieving line) pulled up by the two lifting halyards to the spreaders (or below the lower shrouds if you have to and a control line at the base of the mast. Both lifting boats will heel inboard a little, so it's better if you can take another halyard outboard from each boat to something like a dock or even to the deck of another boat to minimize the heel. The weight is well within the capacity of two halyards with winches, you just have to coordinate it and proceed slowly. You take a strain slowly and just enough to hold the mast before you disconnect the rigging, but you don't take enough strain to jerk the mast up and out of control. If the mast is through deck, your lift has to be a little higher, but the CG is going to be lower. Any way, if you saw it done once, you would realize it's not too difficult, but it's something that should be done with care. The boatyard next my club no longer handles masts because they got burned with liability issues, and I have seen the results of some boatyard incompetence in mangling the headfoils of furlers, but I believe most yards are competent. BTW, most truckers travel the mast alongside the boat on the trailer rather than over the deck, so the mast should be wrapped to protect it and any halyards you leave on it, Also wrap inside (between the wire and the mast) of any rigging or wire you leave on, because it will vibrate and gouge or mark your mast. Good luck whichever way you decide to go. - Joe
Apr 26, 2005
286
Beneteau Oceanis 390 Tsehum Harbour, BC, Canada
Pulling the Stick
I have never pulled the mast on my 39-footer. Man, I would want professional help if I had to. While I totally respect the comments of the other posters, the potential for disaster and damage seems high to me. Those rates seems a hugh deal to this sailor.
