Need a good surveyor on C&C sailboats in Toronto, Ontario
3
C&C 27 Point Roberts, Washington
Hi all,
Just new to this forum (a 1986 C&C 27 owner) and have an urgent need to find an independent surveyor in Toronto, Ontario that is especially knowledgeable on 1990's vintage C&C sailboats (yes - we have seven-foot-itis!) . I am across the country and would appreciate receiving any independent surveyor's contact info that you have dealt with in/near Toronto that you would recommend - preferably one that have seen typical problem areas of 30-40 foot C&C vessels. The vessels I have recently viewed seem to be prone to obvious gelcoat cracking in a variety of locations (mostly corners and gentle bends) but they have also been seen in a few flat straight areas too (over 2 foot long!?). I need to find out if this is indicative of a more substantial problem with the 1990's vintage C&C vessels I am considering. I also need to have the deck checked for potential delamination and moisture content (something I read about in this forum) and am not sure if this is standard practise for a survey. I welcome any and all assistance on finding a good surveyor - or on your experience in investgating the cause or fixing such cracking! - thanks!
May 6, 2012
303
Hunter 28.5 Jordan, ON
I had a few conversations with Wallace while I was looking to buy this past spring and was impressed with his knowledge, credentials, and suggestions. Unfortunately when the time came to arrange the survey schedule he was booked solid. He recommended Peter at Fastnet as an alternative, whom I hired. I was very satisfied with Peter's survey, which I attended, as well as the detail in his final report.
I can send you a copy if you'd like to review it.
