Spec It Out
Marian, I think you are on the right track. You have to find out from your air conditioning manufacturer what the starting current draw is and then match that to the Generator manufacturer. Starting current is larger than the running current. That will dictate the minimum to run the AC. However, some generators have a built-in surge/start up tolerance. The manufacturer can assist you directly.However, running a coffee pot, electrical heater, water heater, hair dryer, etc... basically electrical heating appliances... at the same time you run the AC likely isn't going to happen since you'd have to upsize the genset for these infrequent loads way too much. What you probably will wind up with is a genset large enough to run the AC which you will shut off when you make coffee, run the water heater, etc. At least that is the level of my understanding as to your question. Someone else may have a better answer. Rick D.
