Navionics ipad app
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
I'm sure there are many of us using this app. I just bought myself a 4th generation iPad to play with. I have been using my Eldridge Tide and Current book when planning my weekends. Playing with this app I see the current arrows with drop down charts showing time and speed. My book is on the boat so I can't compare the two. Anyone been using this app long enough to validate its accuracy? It's comforting to know I am going through woods hole with a favorable current
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I can Bob. We have been using that app as our primary navigation planning instrument for the past 3 years. We still use Eldridge and paper charts too. So often I will be at the helm with the iPad. I would have plotted a coarse and be tracking progress using the Navionics app. My wife will have the Eldridge and paper charts. She will follow our progress on the paper charts and check tides/currents in the Eldridge. At night we will review the next days potential coarse and compare. Never found a problem. The only issue is you can only look about a week ahead.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have the navionics app on my iPhone and like it as a reference check. I never tried loading it on my first generation IPad because I didn't think the app was compatible with the older OS. Now that this iPad is older and probably needs replacement anyway, I should probably attempt to load the app. Has anyone else tried to use an older iPad for this?
Mar 7, 2011
36
Beneteau Oceanis 40 Geogian Bay
I do. No problems at all.
Ward H
Nov 7, 2011
3,833
I use Navionics to record every sailing trip but all we do is day sail and have no currents to worry about so not sure about that accuracy.
Last year I used it on a iPad 1 with no problems. The Garmin App would not run on the iPad 1 but I like the Navionics better so no big deal there.
If you do run Navionics on multiple devices, like an iPhone and iPad, it syncs your data between the two devices.
Aug 1, 2011
3,972
I have the Navionics+ on the plotter, and on the 'pad. The only concern I would have with relying on the 'pad is that it will, if it sits in the direct sun for a while, overheat and shut itself off till it cools down. That could be a bad thing if it did that while you were staring at the entrance to a place you've never been.
Cheers
Gary
