Navionics and missing areas of the Atlantic??
Sep 8, 2025
126
Bayfield 36 Lewisporte
Hi,
I would like to sail from Newfoundland to the Azores. I can see the charts for these two but there is no chart available for the in-between area? So will Navionics be able to do an auto route with just those two chart areas?
Also, is the purchase price of these digital charts a one time purchase or a yearly subscription?
To keep the charts updated, there is an annual fee, typically about half the cost of a new chart.
For a trans-Atlantic passage, weather routing is more important than anything Navionics can do. PredictWind does have weather routing and there are businesses that provide weather routing.
Sep 8, 2025
126
I guess what I am wondering is:
I already paid for the subscription to Navionics, which is a yearly subscription. IOT use Navionics for sailing I also need to download charts, some of the available charts are expensive....so IOT keep using those charts that I buy do I also have to pay a yearly subscription to use those charts or does the yearly subscription to Navionics keep those charts that I buy separately up-to-date?
You'll have to read the fine print on the Navionics license agreement to get those answers.
Charts are expensive to produce and they are expensive to purchase. Preparing a boat for a trans-Atlantic crossing will be expensive too.
dLj
Mar 23, 2017
4,823
Navionics is now owned by Garmin. When did you buy your subscription? What chart plotter do you have? It's a little hard to predict what Garmin is going to do with their yearly subscription charts. I have friends sailing in the Pacific Islands that were running Navionics and had chart plotters that would connect to the Internet when available. They were sailing into an island group and Garmin reached in and removed all their charts - without advance warning! They ended up sailing in blind - not fun. If you download your charts and don't have a chartplotter that connects to the Internet then they can't do this
As far as crossing between Newfoundland and the Azores - you don't need detailed charts - there is only ocean there with plenty of depth. There is a base world chart residing in your chart plotter with little detail that you don't see as a chart outline. The program simply uses it for lat/long calculations and plotting a course uses that data. Nothing to worry about.
dj
colemj
Jul 13, 2004
833
Are you using Navionics charts on a plotter or with the Navionics app? If a plotter, those often come with a world map chart that has small scale depth contours (maybe some depth readings). Nothing too detailed, but you will see canyons, mounts, and the like. But there should be nothing of concern in these open areas.
If using the Navionics app, then any charts you download onto the device stay there when the subscription expires. However, any change to the device, or removal (possibly update) of the Navionics app, will wipe them out. The Navionics app does show depth contours and their numerical values for areas where there is no chart subscription. Also land masses without detail. This is enough to navigate safely through these non-subscription areas.
Mark
Nov 22, 2011
1,283
Ericson 26-2 San Pedro, CA
dj
Here's a case involving the removal of charts for Southeast Asia:
Sep 8, 2025
126
Hi,
Not sure what chartplotter I have....just acquired the boat...well by the end of the month. I think the write up said a "Raymarine E7D "?
Right now all I have is the Navionics App with the Canada chart.
Sep 8, 2025
126
Mark
Hi,
Do you really need a chart of the open water mid-Atlantic?
You definitely will want a compass heading and a GPS position of the departure and intended location for landing in the Azores.
There are several sources that can provide this information at a minimal cost.
  • OpenCPN is one being used by sailors.
  • LuckGrib.com is a weather-based passage-making system that is designed for Apple products.
  • Even Windy.com can be a useful tool to cross open water.
More so than a "Chart" from Navionics, you can get a paper chart of the North Atlantic at a chandlery. This will give you the necessary information to safely navigate from Newfoundland to the Azores. Sure, it is old school, but it reduces the worry that you will have no power available to operate your electronic charts.
A higher priority than a chart is having a reliable source of weather data. You want to be able to avoid the big storms that wander across the North Atlantic at all times of the year.
dLj
Mar 23, 2017
4,823
Questions: Do you know how to plot a great circle route? Do you know how to find magnetic deviations for different lat/long?
dj
Sep 8, 2025
126
dj
Hi....Yes....was a military pilot for 35 yrs (S&R/Transport/Tactical). Reasonably familiar also with grid tracks for northern navigation :). But the sailing stuff is new territory :)
dLj
Mar 23, 2017
4,823
Sounds great! If you have any questions, ask away...
dj
