Navik control line set up?
Oct 30, 2019
114
The photos in the instruction booklet do not show clearly how to set up the control lines to the tiller. I guess a couple of pulleys need to be fitted on the cockpit combing but what sort of attachment is used on the tiller? I assume it needs to be adjustable?
Also, there is a black plastic "adjuster thing" - how does that work and what is the purpose of the "screw on" cap at the bottom of the plastic bit? I daren't undo it in case a million springs and washers fly out!
If you have one you will know what I mean, hopefully!
Thanks
John
Oct 30, 2019
1,459
Hi John,
Here's a link to some photos of my Navik setup (thanks Walt!)
There're also some measurements that might help with the line layout noted on some of the pictures.
Hope this helps ...
Peter
#1331 'Sin Tacha'
Dec 5, 2007
144
Peter and all,
the hardware that is on the side of the tiller, what is that called and where could someone obtain that in the US, thanks,
Bruce
s/v Cygnet # 169
