navigation software
May 24, 2003
19
Just got a new laptop and want to connect the gps. Any ideas on
what the best navigation software is for the pacific northwest?
Any info would be appreciated.
Jim-vega 1838
Oct 30, 2019
109
I'm very happy with an inexpensive program I have called Memory Map. The main
reason I chose it, however, was that I didn't want to take my notebook computer
onboard (risk of salt air damage and the greater power draw) and so picked up a
Pocket PC (like a Palm Pilot) very cheap on eBay -- I think Memory Map may be
the only software so far running on palmtops (also runs on notebooks, of
course). It does the usual navigation stuff, transfers waypoints easily between
the GPS and palmtop and desktop PC, shows you your position live on the
on-screen chart, is easy to make routes and transfer them, and uses standard
MapTech charts available on CDROM, diskette (for single charts), or web
downloads (you can get Canadian charts too over the web). It no doubt lacks some
of the fancier functions of the more expensive navigation programs, but the
Pocket PC's power draw is minimal, its battery holds a charge much longer than a
notebook, and the thing is small enough to put into a small waterproof box with
a clear top that I use in the cockpit in the rain. After a couple seasons in the
Northeast, I'm still very happy with it. You can easily find Memory Map's web
site with a web search, and they have links to the makers of the electronic
charts as well as a good demo version to check out free (all functions except
the GPS connection). Good luck.
Tom
Vega 1240 "Allegro" Downeast Maine
vega1838 wrote:
Nov 8, 2001
1,818
Hi Tom
Try out Seaclear. Free to download and runs free bsb and scanned charts.
Works a treat but needs a notebook PC that can be picked up for a couple
of hundred dollars on ebay. Try Seaclear on you home PC and see what it
is like. I personally use SeaPro which is a top of the range, and
expensive, program that works beautifully but at a cost.
Kind Regards
Steve Birch Vega "Southern Comfort" V1703
