Nauta holding tank odor
4
Morgan 30' OI greenwich bay
My Nauta flexible holding tank emits a terrible odor. It was never pleasant, but it has gotten worse as time goes on. I checked all the fittings, re-tightened everything, and checked for leaks. I can't find a thing. Should this have some kind of charcoal filter attached to it? Any help would be greatly appreciated.
Dec 2, 1997
9,011
- - LIttle Rock
Is the odor inside the boat, only out the vent or both?
If it's inside the boat, check the seams and the tank for fraying and chafe-through. If you only have odor out the vent, that's an unfortunate characteristic of bladder tanks, and why they aren't a good choice for waste holding...because they're designed to hug the contents and expand and contract, there isn't enough airspace to provide sufficient air/oxygen to keep the contents aerobic...which is the key to eliminating odor. If it's gotten worse recently, try thoroughly flushing out the tank with plenty of clean water...and try a product called Odorlos instead of whatever you're using now. Neither will cure the problem completely, but it should help.
