idaSailor Rudders: which one?
I know they work good, from your and others posts, but theres more than one choice for the D.-can you comment on pro/cons' of each?thankS!-------------------------http://www.idasailor.com/catalog/product_info.php?cPath=25&products_id=28Mac26d tall high-performance blade $279.00 Click to enlarge HDPE rudder blade, 3" leading edge, 11 3/4" overall, NACA 12 airfoil, 56" overall length, requires relocation of the pivot hole in your boat's rudder castle. Reduces weather helm, helps boat point higher, reduces helm effort. Lifetime guarantee. This blade offers the same performance enhancements as our standard high-performance M26D rudder blade, same draft, same chord length and draft. This blade puts more rudder material into the rudder castle and REQUIRES RELOCATION OF YOUR PIVOT HOLE by 5 1/2" upward. We offer this blade for Mac owners whose rudder castle has a pivot hole that is excessively worn, or who prefer a more unitized blade/castle assembly. Please be aware that you will need to drill a new hole in your rudder castle to use this blade, this blade comes completely undrilled to allow a custom fit to your rudder castle. --------------------------------------http://www.idasailor.com/catalog/product_info.php?cPath=25&products_id=32Mac26d high-performance blade $249.00 Click to enlarge High performance replacement rudder blade for the M26 daggerboard sailboat built from late 1986 until early 1989. Carved from solid hdpe, faired to an ideal NACA 12 airfoil shape. Lifetime guarantee. This rudder blade helps reduce weather helm and tiller effort. This is the blade that has been helping Macs win races all over the country. It's faster, with more control, boat points higher and allows the boat to accelerate in puffs without rounding up. This rudder blade is a drop-replacement for your boat's original blade, no modifications to your boat are necessary. In order to allow for a more perfect fit with your vessel, the blade comes with the pivot hole and other holes undrilled. If you would like us to drill the blade pivot hole and other holes, please let us know in the notes section of your order during checkout. =====================================I'm guessing, the TALL is the way to go, IF I send the castle to them.... they will drill the castle, and blade and return?BUT, the other sounds like a drop in replacement, so quicker repair.... (IS IT worth the effort, cost and hassle for the tall one?)thankx again!
