John:
I am not familiar with the Nature's Head composting toilet; however, after looking at their website it appears that the unit is similar to the Clivus Multrum composting toilet. The Clivus Mutrum has been around for years.
The theory behind composting toilets is sound. Eliminate the water that is typically used to convey the waste away from the facility and just deal with the solids. A composting toilet is also a 'green' solution like they say. Conserve water, save the planet and all . . .
However, odors have been a continuous problem with composting toilets for as long as they have been around. They require
a lot of ventilation. I would probably avoid it.
To combat the odor thing the Nature's Head utilizes a continuous 12 volt dc power source to run a ventilator. The website says:
[FONT=Trebuchet MS, Arial, Helvetica][FONT=Trebuchet MS, Arial, Helvetica]A simple 12 volt computer style fan drawing less than 1 amp is the only power required for this unit. The power hookup, a single pin attachment with a wire length of 6 feet, is also included. It may be necessary to extend the length of the connecting wire. The fan may also be powered by a 110 volt source with an appropriate power adapter that reduces the power to 12 volts! These power adapters are available through many electronic supply houses and will be available through Nature's Head Inc. As with all electrical connections, be sure your Head is on a fused circuit. (The fuse should be no less than 2 amps and no more than 5 amps.) This unit can also be installed in a completely powerless installation by using a solar vent on the roof or cabin top and attaching the vent hose underneath. Be sure and use a solar vent with battery back-up so your Head will vent continuously. The fan can be left in the unit if you choose this option.[/FONT][/FONT]
So in addition to installing the head you need to ensure adequate ventilation and power. Finally, at $850 it is rather expensive.
