Nature's Head Composting Toilet
Styx
Sep 6, 2011
98
S2 8.0C Erie
Anyone have any experience with Nature's Head composting toilet? I am refurbing an S2 8.0C. Because of neglect and damage, I have removed everything from the head and am in the process of fiber glassing the entire head interior. I want something easy to clean. I have looked at Nature's Head composting toilets at a couple of boat shows. Generally, there will be two of us sailing and hopefully for extended amounts of time.
Any advice is appreciated.
Dec 2, 1997
8,913
- - LIttle Rock
Composting is a terrific concept, but IMHO, it's not quite there for onboard use yet. "Nature's Head" seems to be very similar to the AirHead..http://www.airheadtoilet.com Neither of which is a true composter but a dessicator. The main drawbacks to onboard composters and dessicators are:
1. What to do with excess liquids. 90% of human waste IS liquid...mostly urine, but even solids are at least 75% liquid. Excess liquids have to be drained off , or you have wet soggy organic material...and wet soggy material doesn't compost, it rots. Adding dry material--peat moss is the recommended material 'cuz it breaks down quickly--regularly helps some, and there's usually more liquids than the evaporator--which, btw, requires power--in the self-contained units can handle either. Both the AirHead and Nature's Head separate urine from solid waste the urine is directed into in jugs (or a tank). You can't legally drain 'em overboard (unless you're at sea beyond the 3 mile limit), so the jugs must be stored and carried off the boat or the tank must be pumped out same as any other tank. So I can't see much advantage to this over a portapotty.
2. Even though urine is collected separately, solid waste is 75% liquid, so peat moss is needed to keep it dry. Enough peat moss to keep the thing working during an extended cruise can take up more storage space than a holding tank.
3. Composters need a 3" vent stack... AirHead originally specified a 3 vent but is now claiming that a 1.5 vent is adequate.
4. Continuous power 24/7 to run the evaporator.
5. Composting only works in temperatures above 70 F....and only works really well above 75. Below 70, bacterial activity becomes increasingly sluggish--TOO sluggish to make anything happen. So you have to keep it warm all winter--that's 24/7--or waste will just sit there. The good news is, nothing stinks much in cold weather either.
That's my $.02 worth...But you may decide that this thing is greatest idea since the pop up toaster.
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
Nature's Head
Suggest you do a forum search on "composting head" ... plenty of info ...
you might also check out the "other" sailing forum website .. plenty there too.
Peggy's right about the liquids ... you have to figure out how you're going to dispose of the liquid.
I've got a Nature's head and use the original 1.5" deck pumpout fitting for my ventilation ... no problem with 1.5" in my case.
Instead of peat moss ... coconut coir comes in nicely compressed bricks
It's not really composting - but there's no odor and it's not unpleasant to clean out.
All in all ... depending on how you use it ... for me it's a great solution ... for you --- ????
for power usage ... I'm entertaining the idea of a small solar/battery setup like the Nicro Day/Night ventilator uses ..
