National Bimini Tops
May 10, 2004
182
Catalina 30 Puget Sound
I wouldn't purchase anything from them, but then I had a bad experience. Ordered a sail and it arrived all screwed up. I had to return it for the proper replacement. Dirk, the owner refused to pay the return postage for their screwup. The next sail arrived with the bolt rope on the luff for the furler too small. It wouldn't stay in the track. Decided to have it repaired locally. I did, but don't use the sail. It just doesn't trim right. SS
CJRoxs
Jun 13, 2014
8
Catalina 250WB Portland
Thanks for the info. I'm still not sure if I will buy from them. I will be modifying the bimini if I buy one so returning won't be an option. I need a 4' bimini but cannot find one anywhere. I don't want to have one special made as the price goes up substantially. I can modify the frame and fabric myself. I thought about just making the whole thing but it would be about the same price and a lot more work then to start with one that is close.
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Try Ameri seam.They make them for Catalinas.This site store should be able to help.If not they can.Friend had one made ,good price and quality.
Aug 1, 2011
3,972
I bought a drifter and a cruising chute that was a custom spec, and they were just fine. My boat came with Rolly Tasker main and 110 furler and they are both fine. I'd have no issue ordering stuff from them.
Jul 23, 2013
487
1981 Catalina 22 #10330 Bayview, ID
Check out Marine and RV Direct. They have some 46" kits that might work for you. I'm very happy with the bimini that I purchased from them and describe on my blog at Budget bimini solution.
Aug 1, 2011
3,972
Meriachee, you do mean National, not Ameriseam correct?
Yes. me bad, I saw National and somebody referenced Dirk, who is the guy at National Sail Supply. He's in Florida, and this bimini place is on the left coast.
