Name this part
Joe
Does anyone know tha name of the J-shaped bolt that stick into the end of the spreaders on the H23 (1987)? It goes thru the black plastic piece and hold the wire. Any ideal where I can get one, I'm missing one on my boat. Thanks
G
Greg Stebbins
No idea but....
You can order a new on from US Spars (www.usspars.com). Mast No. is Z190 Pt No. is 1481. Will that do? (-: Greg H23 Faster-
Dave Condon
which mast
Joe; Is your mast Kenyon/Isomat or Z Spar. There should be a sticker on the mast and if not, maybe I can inquire knowing what the hull number of your boat is. Maybe then I can Help you better Crazy Dave
G
Gary H.
Francespar
It sounds like you have a Francespar like mine 87 H23. Check out the www.rigrite.com web page. There is a discription and size listed there. I ordered new exit plates and received them the next day.
Joe
Spreader end hook
This is what the guy called the part at www.usspars.com. I appreciate you guy and your help. The part is on it's way.
